Speedometer problems..works,doesn't work
Old Aug 8, 2004 | 01:46 AM
micsteam's Avatar
micsteam
Default Speedometer problems..works,doesn't work
I just bought a 1988 GT T-top car and the guy said he replaced the cable, which I verified, but the speedo still is sporatic.. I'll get in the car and at first it won't work then all of a sudden bing ! it's working. I checked at the trans and everything appears fine, no loose connection or broken parts. Should I check at the back of the cluster ?? Does anyone else have/had this problem, is it common ?? Help !!
Old Aug 8, 2004 | 01:01 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: Speedometer problems..works,doesn't work
yes it is common..I would just opt for a new one....a nice white face gauge look nice..also did you check the speedo gear in the trans?
Old Aug 8, 2004 | 01:41 PM
roundman's Avatar
roundman
I would check at the dash cluster and make sure it is plugged in all the way to the speedo first, sounds like it ain't plugged in all the way and sometimes it catches and drives it and sometimes is don't catch and it don't drive it.
Nurdyguy
Jan 20, 2025 04:38 PM
MustangGirl98
Aug 2, 2016 08:10 AM
67LimeCoupe
Nov 25, 2015 08:55 PM
MusicCity615
Sep 27, 2015 12:53 AM
Mr. D
Wheels & Tires
15
Aug 22, 2015 02:58 PM
