TPS?
Old Nov 2, 2006 | 06:02 PM
92hatchLX's Avatar
92hatchLX
Default RE: TPS?
I've got a good one for an 8 cyl. that I'll let go for 10 bux.
Old Nov 2, 2006 | 06:03 PM
iamvillani's Avatar
iamvillani
Default RE: TPS?
F**K I JUST PAID 50 BUCKS FOR A BRAND NEW ONE AND I DON'T EVEN KNOW IF THIS IS THE PROBLEM
Old Nov 2, 2006 | 06:05 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
Default RE: TPS?
50? you were robbed thier about 25-30
Old Nov 2, 2006 | 06:09 PM
iamvillani's Avatar
iamvillani
Default RE: TPS?
GREAT
Old Nov 2, 2006 | 06:14 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
Default RE: TPS?
sorry[&:]
Old Nov 3, 2006 | 11:34 AM
iamvillani's Avatar
iamvillani
Default RE: TPS?
So I get home last night and pop the hood and the TPS on there looks brand new. So I changed it anyway. After I changed it I sprayed the sh*t out of the TB. Car ran good then started to buck a little then was ok no where near as bad as before though, car idils like a charm by the way. It would buck every now and then but if i ride the clutch a little I can get passed it. Does this seem like just a carbon problem? Anyway i put the old TPS in and no different so I returned the new one this morning and got my 'ripped off' 50 bucks back. THX
Old Nov 3, 2006 | 01:45 PM
Joel5.0's Avatar
Joel5.0
Default RE: TPS?
You were lucky they took it back.....start by running a DIY KOEO/KOER self-test combo.......+ check the KISS items....plug wires touching the headers, plug boots burnt causing spark to arc some times, dizzy cap & rotor.........
Old Nov 3, 2006 | 01:54 PM
iamvillani's Avatar
iamvillani
Default RE: TPS?
Thanks I'll give that a whirl. Im having my computer checked for codes on tues. i hope i can pull some do to my car was a 4banger and is now a 5.0. I know he switched the computer correctly but i heard sometimes you can't pull codes on a swap. We'll see.
Old Nov 3, 2006 | 01:59 PM
Joel5.0's Avatar
Joel5.0
Default RE: TPS?
If the swap was done correctly, pulling codes shouldn't be a problem...if it is, either something was installed wrong or the ECM is bad.
ShaneB26154
35
Mar 4, 2021 04:05 AM
mirandaandjimmy
Nov 16, 2015 08:51 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
69MustangCoupe393cid
Oct 3, 2015 10:33 AM
bmorrisj
May 27, 2004 06:18 PM
