stuck
Old Nov 4, 2006 | 10:36 PM
burn rubber's Avatar
burn rubber
Default stuck
i can be sitting at a stop sign in neutral. when i goto throw it into first it does not go. it wont go into any gears. im stuck sitting there for trying to force it into gear.
Old Nov 4, 2006 | 10:56 PM
fourfivefour's Avatar
fourfivefour
Default RE: stuck
Your clutch is not releasing enough. If you don't have an aluminum quadrant and adjustable cable get it.
Old Nov 4, 2006 | 11:00 PM
burn rubber
Default RE: stuck
is that hard to put in
Old Nov 4, 2006 | 11:05 PM
SRVirtual's Avatar
SRVirtual
Default RE: stuck
^ I had the same question I have the plastic adjustable quadrant and I have a brand new clutch cable in and i have to push my pedal to the floor to get it to not grind into gears. I dont have any slipping in my gears so I dont think my clutch is going and was thinking of just putting an adjustable clutch cable and aluminum quadrant in but wasnt too sure if it was easy to install myself or if I should get someone to do it for me.
Old Nov 4, 2006 | 11:11 PM
fourfivefour
Default RE: stuck
I have the Steeda 3 piece kit (adjustable cable, firewall adjuster, and aluminum quadrant) in both of my cars. The kit comes with directions that are simple to follow.
The easiest way to change the quadrant is to remove the drivers seat and lay under the dash. The quadrant is above the gas pedal. Remember how you removed the old cable so you know how to route the new one.
Old Nov 4, 2006 | 11:12 PM
burn rubber
Default RE: stuck
how much does that cost? and where can i get it at b4 the week is out?
Old Nov 4, 2006 | 11:15 PM
SRVirtual's Avatar
SRVirtual
Default RE: stuck
50resto.com and its about 100 bucks
Old Nov 4, 2006 | 11:21 PM
burn rubber
Default RE: stuck
thanks alot
fourfivefour
Default RE: stuck
I seen an advertisment on here at the bottom of the page for a Steeda kit for $99.95 with free shipping. Dont remember who it was from.
Old Nov 5, 2006 | 03:16 PM
cbennett's Avatar
cbennett
Default RE: stuck
+1 on removing the seat.. thats what i should have done..
