Running Lean
Old 06-28-2003, 10:03 PM
95stang
95stang's Avatar
Default Running Lean
I have a '95 GT and have upgraded to a cold air intake, 80mm MAF, 65mm throttle body, adj. fuel regulator (42psi), 1 5/8" unequal shorty headers, prochamber h-pipe, and digital air/fuel gauge. Only now the check engine light comes on time to time. Gauge reads .14 steady acceleration, .98 after letting off, then down to .03 after coasting for a bit. I don't see any vacuum lines off and have changed the O2 sensors and PVC valve. Has anyone else had this problem from these kind of upgrades?
95stang is offline
Old 06-30-2003, 09:48 PM
n2o44
n2o44's Avatar
your maf calibrated , i assume you gauge read lower vol mean richer and higher is leaner? if you coast its gonna go lean what are your codes you have?</P>
n2o44 is offline
Old 07-04-2003, 01:06 AM
95stang
95stang's Avatar
When the light first came on I had stock MAF cal. for 19#injectors (now it's 80mm w/ stock electronics). The place where I got the gauge says it should be .3 to .7 volts at idle(closer to 1.0 volt you get the richer it is) and from .7 to .9 at WOT. I was thinking of trying to clean the wires, then switch back to K&amp;N induction kit, and then new O2 if the other attempts fail. The codes were lean mixture left and right banks...and SPOUT circuit grounded.<edited><editID>95stang</editID><editDate>37805.9635300926</editDate></edited>
95stang is offline
Old 07-05-2003, 11:34 PM
95stang
95stang's Avatar
Switched back to my K&amp;N FIPK and the check engine light hasn't came back on. The bend in the CAI before the MAF sensor must have been the culprit.
95stang is offline
Old 07-07-2003, 04:49 AM
n2o44
n2o44's Avatar
ahh you may be right there is some tweeking i have heard of the maf . when u start getting that kind of stuff . it obviously changes the intake track , i dont know how the bend goes but twisting the maf acordingly should give you better readings . i forgot the logic behind this but obviously the air moves at diff speeds on the short side of the turn than the longer one . i heard this on a tweecer board . he had to adjust his maf curve due to a cold air ontake . to make it short he had to tweek it a lil i think at the 10 o clock position . his car did breath better but he was wondering why he had to go and adjust the maf curve . example xxx of voltage i xxx of kg an hour of air . i wound up that the new intake track he had created skewed the maf reading thats all . sound like this may be your case ??? not that its bad just your maf did know what was goin on thats all . leme know
n2o44 is offline
Old 07-15-2003, 11:09 PM
95stang
95stang's Avatar
I ended up trying all kinds of different combos on my CAI.Anyway I tried switching my stock electronics from the MAF to the MAF electronics from a 98 Cobra that I had. When I did this the car ran the best it had in a long time. So I got to looking at both sets of electronics. Come to find out the 95 sensor had a lot of gunk on it (probably from the K&amp;N oil) so I cleaned it off with heavy duty brake cleaner. It worked...light doesn't come on and fuel pressure is down to 36-38psi and the A/F gauge reads as it should.
95stang is offline
Old 07-17-2003, 10:56 PM
vfast
I ♥ Acer
vfast's Avatar
that 80 mass what kind? 80 is a lil big for what mods I saw..
vfast is offline
Old 07-18-2003, 12:31 AM
95stang
95stang's Avatar
The 80 is a little big for now but I was looking on down the road to when I have the funds to get a Kenne Bell SC.</P>
95stang is offline
Old 07-18-2003, 08:20 AM
vfast
I ♥ Acer
vfast's Avatar
that's good insight but it's hurting you now..what kind is it?..if it's a c/l make sure you have the right sample tube<edited><editID>vfast</editID><editDate>37820.2645833333</editDate></edited>
vfast is offline
Old 07-18-2003, 08:22 AM
vfast
I ♥ Acer
vfast's Avatar
what happens to fuel pressure when you lean out?
vfast is offline
Quick Reply: Running Lean
