which cam would you recomend?
Old 07-18-2003, 01:38 AM
falconkid4478
falconkid4478's Avatar
Default which cam would you recomend?
I have a 93 GT and i want to get a cam. which brand and type would you recomend?
falconkid4478 is offline
Old 07-18-2003, 01:39 AM
Sean
Sean's Avatar
Do you have to pass emissions?
Sean is offline
Old 07-18-2003, 02:24 AM
Jugador1
I ♥ Acer
Jugador1's Avatar
i dont get cams with all the degrees and such...i understand the purpose and how it works, but can we get a little lesson on cams? </P>
*cough*<FONT size=1>jeep</FONT><FONT size=2>*cough*</FONT></P>
Jugador1 is offline
Old 07-18-2003, 08:18 AM
vfast
I ♥ Acer
vfast's Avatar
need to know what mods you have now and mod you plan on using
need to know exhaust,headers,intake,heads,gear,trans,etc
vfast is offline
Old 07-18-2003, 12:25 PM
Mysterious
Mysterious's Avatar
If you want to know about cams, Let me know. I havent been to sleep yet, and I am really tired. AS far as a stock 5.0 I recomend a Comp Cams Extreeme Energy hyd roller. Keep it under the 274, autos will need a 2400 stall or so. 5 spds should work okay. It needs the springs swapped as well. Add roller rockers, not just the tip, but full roller rockers. A set of AFR 165heads, good headers, x or h pipe, and a Performer RPM intake, bigger throttlebody and poof. You are screamin right along. That thing would haul.... bigger injectors would be a plus
Mysterious is offline
Old 07-18-2003, 02:35 PM
horatio102
horatio102's Avatar
I went with the Motorsport F303.... I love it. On my truck I went with the conservative of the two I was looking at and I'm not sure I'm happy with my decision (don't get me wrong, it makes decent torque).
Lumpy idle
off idle to 3000 it feels like my mostly stock setup
3000-4500 it pulls pretty good
4500+ it screams.
I haven't explored the upper ranges of the tach much at all because I just got the motor put together, but I imagine it's quite healthy up top too.
I should note that they forgot to order my maf/injectors/cai so it's down on power right now, but in a week we'll get that fixed.
So far:
70mm tb/egr
power + intake
f303 cam
edl performer heads (not sure why they wanted to go with the edelbrock instead of afr, but there's only a slight flow difference)
mac headers
msd coil
flowmaster 40s
off road h pipe
.030 overbore
forged rebuild kit 8.5:1 compression
horatio102 is offline
Old 07-18-2003, 11:32 PM
Mysterious
Mysterious's Avatar
"E" heads work okay too. I put a set on a Paxton blown 5.0 a few years back. ran pretty well. He went to the x303 in his, lost a bit of power, but still ran good.
Old 07-19-2003, 11:55 PM
Buzzstang
Buzzstang's Avatar
b303 ford motorsport cam
Buzzstang is offline
Old 07-20-2003, 12:35 AM
vfast
I ♥ Acer
vfast's Avatar
horatio.....that's low compression and isn't those heads like 62-64 cc? is a S/C in the future?
vfast is offline
Old 07-20-2003, 05:02 PM
horatio102
horatio102's Avatar
vfast - oh yeah! <img border="0" src=smileys/smiley16.gif border="0">
It was also balanced while they had it out.
I have a feeling that it's a lot faster than it feels right now. I just don't have a working speedometer so I can't tell you what I've had it up to. I also don't know what gear ratio I've got, but I kinda think it might be stock - 1700rpm at roughly 60mph?
Quick Reply: which cam would you recomend?
