BORE SIZES
Old Aug 13, 2004 | 11:31 AM
DaveAllred's Avatar
DaveAllred
Default BORE SIZES
If i have a 302 5.0 bore'd over it will be a what.........326, 5. what? HELP ME OUT GUYS
Old Aug 13, 2004 | 11:38 AM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
Default RE: BORE SIZES
Depends on what its bored over by? .030" overbore would make it 306 cubes.
Old Aug 13, 2004 | 11:48 AM
DaveAllred's Avatar
DaveAllred
is that even worth the 160 bucks it costs, how much can i bore a 302 block outta a 72 boss stang w/o any trouble?...and what will the CI be..
Old Aug 13, 2004 | 12:15 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
its gonna cost more than $160, your gonna need new pistons and rings to go along with it. Im not sure just how far you can go on that particular block, but usually its .060". And no, its not usually worth tearing down a motor just to bore it bigger, but if you gotta tear it down anyway - it may be a good investment, especially if you gotta have machine work done to it anyways.
Old Aug 14, 2004 | 03:01 PM
tinman's Avatar
tinman
You may want to check the bore size now and see what you've got. It should be 4.000 or just slightly over due to wear. Check all 8 bores while you are there. You'll need an inside micrometer (slow but sure) or a dial bore gauge set at 4.000.
Don't be surprised to see readings of size that are 4.003 or so in one part of the bore and 4.004 or even 4.005 in another. Not all bores are round and they aren't striaght either.
I think that .030 could probably be considered the max size that I'd try for with a regular production block.
If you do find something wrong with the block I'd not be too concered about it as FoMoCo only made about a bizillion of these things...
Old Aug 14, 2004 | 05:16 PM
DaveAllred's Avatar
DaveAllred
Block is already torn apart, sendin it in to get magnaflewd and machined so lookin at things to do now instead of later.............Ill be gettin new pistons and what not so size doesnt matter......Just the 160 bucks to bore, WORTH IT?
Old Aug 14, 2004 | 08:27 PM
Dbeck002's Avatar
Dbeck002
I ♥ Acer
if you can get a bore job for 160 than go for it. As long as you get new pistons for the new bore size. I would go for it if its that cheap!
Oct 1, 2015 09:29 AM
Sep 30, 2015 12:39 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
Sep 29, 2015 03:23 PM
