90 mm maf sensor
I just got a bigger mass air sensor cuz the stock one is too restrictive . But Its to big to fit into my cold air intake pipe. Wats a cheap way of getting a bigger cold air intake pipe instead of spending $230 for a 4" power pipe that will fit?
mac headers , intrax springs,24lbs injecters,msd igintion system,mac cold air,bbk off road x pipe,Ford racing ECU,BBK Underdrive pullys,Holly adj fuel reg, just minor bolt ons. but i got the the 90mm because my stock MAF sensor got water inside of it and its all mess up . I dried out everything but its still not right . Why does it matter do i have run sumthing big to use that 90mm ?
at what sort of N/A power would you guys recommend to go to a 90mm- my car (non-mustang but factory 347 stroker) uses an 80mm Lightning MAF and I reckon it's too small. I'm making 400hp at the tyres and the MAF's pegged at 3000rpm and I was looking at going to a 90mm..... comes with 82mm factory TB too
