High Idle
Old Nov 15, 2006 | 04:12 PM
Swirl's Avatar
Swirl
Default High Idle
I noticed that my mustang has a really high idle. Yesterday it was at 2 grand - :\
Also sometimes it seems to just be all over the place from 1 grand to 1.5 to 2.
I am going to clean out the IAC and check the Throttle body today.
Is there anything else I should do?
Swirl
Old Nov 15, 2006 | 04:13 PM
88blackgt's Avatar
88blackgt
Default RE: High Idle
check your tps voltage
Old Nov 15, 2006 | 04:31 PM
91stang's Avatar
91stang
clean out your IAC valve and then reset your computer by taking the neg terminal off the batt for like 30 minutes... it that doesn't help there's a screw in the back of the tb that you can turn to lower the idle
Old Nov 15, 2006 | 05:09 PM
Swirl's Avatar
Swirl
Thanks for the suggestion.
Swirl
Old Nov 16, 2006 | 01:14 AM
blackcrow_75's Avatar
blackcrow_75
check all your vacuum lines make sure none crack or split
Old Nov 16, 2006 | 12:14 PM
Swirl's Avatar
Swirl
My brother and I cleaned out the IAC and the Throttle body lastnight and that helped some (atleast the gas pedal doesn't stick anymore - )
I will check the other stuff as well.
Swirl
Old Nov 16, 2006 | 12:21 PM
92hatchLX's Avatar
92hatchLX
Clean your MAF too, reset the computer and play with the idle adjustment screw some.
Old Nov 16, 2006 | 12:36 PM
Swirl's Avatar
Swirl
ORIGINAL: 92hatchLX
It's an 87 still has SD -
Swirl
Old Nov 16, 2006 | 01:01 PM
rez_rocket's Avatar
rez_rocket
Change the TPS, my car idled at 2000 when it went bad.
4cylinderplus2
Oct 9, 2020 07:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
svfetter
Oct 5, 2015 11:39 AM
69Volunteer
Sep 30, 2015 10:39 AM
MacSerio
Sep 27, 2015 01:05 PM
