compression calculator?
alot more than you can possibly get out of them. A stock bottom end 85 block had 8.5:1 compression on 64cc chambers in the stock heads. gt-40P's will pring you to atleast 9:1, and if you mill them .030, you can get about 9.5:1
Cast Iron heads shouldn't be used to support more than 9.5:1 compression. The risk of predetonation is pretty high with iron.
And here's this thing:
http://www.carcraft.com/techarticles...ression_ratio/
uberstang1
Sep 20, 2015 06:42 PM
