mass air conversion problems.
Old Nov 18, 2006 | 07:57 PM
88gtboy's Avatar
88gtboy
Default mass air conversion problems.
So I attempted to do the mass air conversion today. I got a mass air harness, mass air unit and a9l. I installed the harness and whatnot and It wouldnt start. It was on my 88. I noticed the fuel pump would not turn on. by the ecu there is a extra plug that did not go to anything under my dash that was unhooked and i noticed to wires cut but the car it came out of was a running vehicle so i figured i could install it so it would run and figure out from there.
Since it didnt work i put my 88 harness back on and its running again.
I think its a issue with my harness, So I just want to take the harness apart, and use the mass air plug with my old harness.
Does anyone have the article to do this using the stock harness wire coloring as refrence as to where to install it?
Old Nov 18, 2006 | 08:11 PM
Black Snake's Avatar
Black Snake
Default RE: mass air conversion problems.
SO what did u do? You got in intire EFI harness or just the MAF harness?
Theres 4 more wires what need to be moved and spliced. One controls the cruise control and the other is for the fuel pump.
Old Nov 18, 2006 | 08:12 PM
Black Snake
Read this https://mustangforums.com/m_842395/tm.htm
Old Nov 18, 2006 | 08:13 PM
motorman524's Avatar
motorman524
MF Informant
here is a really good brakedown on how to do it using your stock harness. http://www.stangnet.com/tech/maf/massairconversion.html enjoy!
Old Nov 18, 2006 | 08:21 PM
88gtboy's Avatar
88gtboy
i used a whole new harness... i guess there was something different with it but i didnt have time to figure itout so i put my 88 harness back on...
ill just use the plug and wires to do the job the article says and hopefully that will take care of it.
Old Nov 18, 2006 | 09:25 PM
primetime5.0's Avatar
primetime5.0
mine was the same way the only real direct swap is an 89 harness, I ended up splicing into the original
Old Nov 18, 2006 | 10:05 PM
88gtboy's Avatar
88gtboy
well I was told It was out of the 89.. that was the main reason i got it.. I cleaned the harness all up and retaped everything to find out that it wont work and ill have to use my old one.. It sucks too its real dryrotted and all the looming is cracking off
Old Nov 18, 2006 | 10:23 PM
primetime5.0
exactly how mine was
Old Nov 19, 2006 | 02:34 PM
88gtboy's Avatar
88gtboy
im thinking im gonna give it another try today and see what happens...
Old Nov 19, 2006 | 02:36 PM
5.0stanger's Avatar
5.0stanger
http://www.corral.net/index.php?opti...d=29&Itemid=26
Best link I found for the swap.
CS2007
Jun 25, 2019 09:45 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
