car runs idles better with vaccum leak?
Old Nov 21, 2006 | 11:59 PM
brywatz's Avatar
brywatz
Default car runs idles better with vaccum leak?
When I bought my "90 gt vert It had a vaccum leak in the hose that goes from the upper manifold to the cannister on the pass side. when I fixed the leak, the car wouldn't idle and would stall. it only idles when I unplug the hose have a big vaccum leak. Anyone know whats going on?
Old Nov 22, 2006 | 12:05 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: car runs idles better with vaccum leak?
Canister as in charcol canister for the emissions?
Old Nov 22, 2006 | 12:07 AM
brywatz's Avatar
brywatz
I think thats what it is. Its mounted to the frame on the front passenger side.
Old Nov 22, 2006 | 12:08 AM
mattdel's Avatar
mattdel
yah it sounds like either the canister is clogged or the line that goes out of it is kinked or something. vac lines are touchy, my car stalls if i plug the brake booster line back on too quickly.
Old Nov 22, 2006 | 12:11 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
It could be saturated w/ fuel and pulling extra from there. Seen mainly on carbed cars though. Maybe a bad canister purge control solenoid.
Old Nov 22, 2006 | 12:13 AM
brywatz's Avatar
brywatz
Is that what is mounted next to the cannister in-line?
Old Nov 22, 2006 | 12:19 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Yeah and it should have an electrical connection on it.
Old Nov 22, 2006 | 12:22 AM
brywatz's Avatar
brywatz
Thanks. I guess I'll have to look into that, I'm totally at a loss. The car feels like it should have more power, is it losing power with this vaccum leak?
Old Nov 22, 2006 | 02:07 AM
musclemustang94's Avatar
musclemustang94
it wont lose power from a vaccum leak since under acceleration their isn't any manifold vaccum, i would say check your fuel pressure too...put a guage on the schrader valve on your fuel rail and see what the pressure is, if its between 35 and 40 psi pinch off the return line and see what it does, if it shoots up then its bad and needs replaced. it would cause your engine to run really rich if its bad, but the vaccum leak would fix this since more air is getting into the engine. If your purge control solenoid was bad then your MIL light would be on.
Old Nov 22, 2006 | 02:10 AM
musclemustang94
btw a leaking injector could cause your engine to run really rich, which would also cause it to stall. A plugged air filter would also cause this too, which maybe why you feel like your low on power.
djbigskrilla
Sep 20, 2022 01:04 AM
msavoia23
12
Jul 7, 2018 12:08 PM
mirandaandjimmy
Nov 16, 2015 08:51 AM
jjwinel78
Aug 17, 2015 03:34 PM
Milan Dragway
Aug 12, 2015 03:43 PM
