no spark. can it be computer?
Old Nov 26, 2006 | 01:54 AM
mike s 95's Avatar
mike s 95
Default no spark. can it be computer?
hi. i have a 95 gt that died today. it sputtered a few times on a long drive then quit a few hours later. i changed the coil and control module and still have no spark. please help with any suggestions. i did notice the check engine light does not come on when i turn on the ignition. thank you, mike
Old Nov 26, 2006 | 02:08 AM
samseed101's Avatar
samseed101
Default RE: no spark. can it be computer?
Just a couple things to check... How is your rotor and distributor cap? How about the distributor itself? Also, if your Profile Ignition Pickup module / Hall effect sensor is bad you won't get a spark either.
Old Nov 26, 2006 | 02:57 AM
Blckstng93's Avatar
Blckstng93
Ignition switch?
Old Nov 26, 2006 | 03:03 AM
aode08's Avatar
aode08
99 percent of time PIP and ignition module. replace, ull be fine
Old Nov 26, 2006 | 12:32 PM
jatyliz's Avatar
jatyliz
I have a 86 5.0 where is the PIP sensor located at?
Old Nov 26, 2006 | 06:30 PM
mike s 95's Avatar
mike s 95
i have no spark from the coil. what is a pip? thanks for the replies, mike
Old Nov 26, 2006 | 06:35 PM
settled4automatic's Avatar
settled4automatic
the PIP is the Profile Ignition Pickup deal inside the distributor housing. to replace that, you've got to remove the distributor, and disassemble it --- its not fun.
Old Nov 26, 2006 | 06:39 PM
Stanpower's Avatar
Stanpower
http://www.aa1car.com/library/2003/us80312.htm
Old Nov 26, 2006 | 10:47 PM
mike s 95's Avatar
mike s 95
would the pip make it so i have no fire at the coil? thanks. mike
Old Nov 27, 2006 | 11:13 PM
x sno snake's Avatar
x sno snake
I have a similar problem with my 94 GT 5 Spd. Is/can the PIP do a slow/intermitent fail? Ie: not start, turn off the key and retry and get a start. Have new cap/rotor/wires(frpp)/plugs and fuel filter (normal pm recently), tried 3 coils and 2 MAF's. Do have fuel press. at the fuel rail schrader valve - yup, it's messy but minimal.
Do you need any special tools to replace the PIP? Is it a NAPA or Ford only part?? Recommendations on it or replace the whole thing with a Mallory or ?? Had a Jacobs package with High Energy coil - it was a POS, back to stock for now. Only other mod. so far is the K & N and the tonneau covers. Have a cold air kit and 75mm throttle body (BBK), will the computer handle that or get it PO'd? There's a guy over on the 4.6 side with similar problems - is the PIP across the board or unique to the 5.0's?
Thanks for any help
