I need timing help
After reinstalling my 5.0, I'm having trouble timing the ignition timing. When running with the light, what degree should I see on the balancer marker? Right now its running at 30BTC at idle and it has a very slight studder. I'm not sure which way to adjust it. I have the distributor at optimal running at this degree.
ORIGINAL: jettin169
gotta remove the spout connector to set base timing.
then the EEC will set total timing based on readings it gets form sensors.
set base at 12-14 and go from there, sometimes they take more sometimes not.
mungodrums
Oct 7, 2015 04:01 AM
Sep 8, 2015 11:50 AM
