compression test
Old Nov 26, 2006 | 05:10 PM
86onboost's Avatar
86onboost
Default compression test
i was checking the compression on the 87 5.0 mustang what is the compression supposed to be on all cylinders
Old Nov 26, 2006 | 05:17 PM
86onboost's Avatar
86onboost
Default RE: compression test
bump
Old Nov 26, 2006 | 05:22 PM
93 LX FiveO's Avatar
93 LX FiveO
as long as all the cylinders are in the same range there shouldnt be a problem
most ppl seem to get around 120-140
Old Nov 26, 2006 | 05:23 PM
PX429's Avatar
PX429
It's supposed to be differant on all cylinders. Quick Question. How did you perform the Test?
Old Nov 27, 2006 | 02:44 AM
Twisted's Avatar
Twisted
ORIGINAL: PX429
What? Ideally, compression should be as close across all cylinders as possible.
Old Nov 27, 2006 | 03:05 AM
nmerrill's Avatar
nmerrill
^=1 its supposed to be balanced
Old Nov 27, 2006 | 03:10 AM
cobra81's Avatar
cobra81
ORIGINAL: PX429
to do the test u need to dit a compression tester for autozone, pull a plug out screw the tester in the plug hole, pull your coil wier off and turn it over untell the needle stops moving, workes best with 2 people
Old Nov 27, 2006 | 03:11 AM
locosrt4's Avatar
locosrt4
how to u preform the test and wht do u need to do it
thanks
-edward
Old Nov 27, 2006 | 03:32 AM
FiveLiterRiceEater's Avatar
FiveLiterRiceEater
first, remove all spark plugs. second, disconnect ignition source (the coil wire) hook up your compression guage (threads in where a spark plug was) hold the gas pedal to the floor and crank it for a few seconds (about 3 seconds) record your reading. i do this about 3 times per cylinder. should be about 120 - 140 and no cylinder should drop less than 20 % of the highest reading .. so if your highest reading on a cylinder is 140 then your lowest cylinder should be below 112 (140 x .20 = 28 140 - 28 = 112)
Old Nov 27, 2006 | 03:41 AM
Mowin8603's Avatar
Mowin8603
ORIGINAL: FiveLiterRiceEater
you mean shouldnt ??
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
Florida Regional Chapter
Sep 30, 2015 08:04 PM
GT350 S550 Tech
Sep 29, 2015 03:29 PM
