what next mod
i have a 5.0 and i have stock heads, cam, and no electrical or carb intake.
whatshould my next mods be i have 300 bucks, and i thinking of a air gap elderbrock intake, but i do not any any after market heads or cam, so what should i get.
is there any aftermarket heads for 300??? used?
or cam???
or cam???
iron gt40's sell for $300, you would only bolton about 25 hp if you don't port them a bit, you can spend just a couple hundred bucks on porting the exhaust, and a good valve job, bolt on closer to 45 probably
heads , gears and nitrous are the 3 biggest improvements you'll see for the money
ORIGINAL: 86onboost
for drag application also, and also any if u can tell me wat brand and type please
yeah im leaning towards it now, but i head installing them yourself is hard becuase you have to use like a magnet and have to be presice and it you mess up that it could tear it up .... but if yall want to hekp me out on that and lead me on step by step it worth a try.
also i using a c-4 tranny so is there certain gears for auto tranny, or can i use just the regular 8.8 pinion and gears
