Computer
It should work, but I don't know how well.
If you do go this route on the 302 swap, it will be easier to take everything from the donor car. sensors, harness, computer, ...
I don't know anything about the Crown Vic computers though.
A crown vic computer isn't the way to go. They have a completely different firing order than the HO 302/351w. Everyone that does the HO swap in a crown vic switches to a mustang computer, so I'm sure you'd be better off with a HO computer.
Would it be possible to put a carb on it?? What about dumpin in a 351W and makeing it carborated?? Would it be alot of work and would I be able to pass emissions with it like that?? (I live in Indiana).
Making it carbuerated is easier than doin a whole cimputer/wiring harness swap. As for will it meet emissions, thats hard to tell, youll definitly need cat. convertors (probably like 4 of them). what you need to do to make it carbed, is a carb inatke and a carb, and a distributor with the ignition module on it. Then you simply hook up your wire harness to the disty, make sure you get a fuel pump intended for carbs (5-10 psi). Oh yeah, you might also need a throttle cable off of a '85 GT 5-speed (auto's were EFi).
-P.
-P.
