Drag Springs
In the Jegs catalogue it lists Moroso Drag springs, but says in bold print they are "NOT FOR STREET APPLICATIONS!!!" Is there a reason for this, or is it just illegal like off road H pipes and stuff?
ORIGINAL: PRO50SC
If you cut them then what would be the purpose of having them?
ORIGINAL: rsw007
there fine but you will have to cut them or look like a 4x4. and there a pain to get in.
compressed
un-compressed
My 2640# (without driver)'84 GT hatch really looked like a joke when I first put them in. Cut-off 2 full coil and I think it's STILL too high.
Yep, they are sort of a bummer to install/de-install.
Use an air powered abrasive cutter to cut them off...
Ok for street use, I really don't think so. Moroso gets a LOT of $$$ for them.
Maybe find a set of 4 cylinder springs at the junker yard, may really work better and be lots less $$$........
i forget who it is, one of the guys w. a primer color car on here(no offence, i just remmber you by your car, lol), i wanna say maybe grabbem88? anyway, he has eibach drag springs, and it sits very nicely, i think he said he didnt have to cut his... maybe hell see this and chime in
the moroso springs (for the rear) say not for street use because they arent the same. the right one is shorter and very stiff and the passenger side spring is longer but softer. its designed to dig the right rear wheel in harder on launch.
for front springs i would just get some 4 banger front springs from the junk yard and throw them in. stock rear springs are pretty good
