91gt problem
Old Nov 29, 2006 | 07:17 PM
92cobra's Avatar
92cobra
Default 91gt problem
Well i just bought a 91gt and when i go full throttle on it, at around 3500 rpms it will start surging, as if the engine isnt getting enough gas, and it wont go passed about 4k. I just got a tune up, changed the oil filter, oil, plugs, wires, but im still having the problem, any idea to what might cause this?
Old Nov 29, 2006 | 07:40 PM
mattdel's Avatar
mattdel
Default RE: 91gt problem
mine does that randomly through the RPM range when floored. fuel pump is bad.
Old Nov 29, 2006 | 08:19 PM
Stanpower's Avatar
Stanpower
http://www.aa1car.com/library/2003/us80312.htm
Old Nov 29, 2006 | 10:27 PM
cheetha94607's Avatar
cheetha94607
check the easy stuff first like fuel pressure and try to replace the filter to see if that helps.
Old Nov 29, 2006 | 10:33 PM
ddeaton66's Avatar
ddeaton66
Fuel pump is prolly gettin weak or if you are lucky a filter needs changed.....most likey items at any rate. Runs fine @ lower rpms/power settings right?
Old Nov 29, 2006 | 10:55 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
check fuel pressure at different rpms
check timing
Old Nov 30, 2006 | 11:35 AM
ruger311's Avatar
ruger311
dotn for get to check you plug wires one might have came loose, check you FP or install an AFPR and gauge, clean the injectors also
Old Nov 30, 2006 | 04:25 PM
92cobra's Avatar
92cobra
im gonna find a mech and have them check to see if the fuel pump is working today. Anyone know how much a fuel pump should cost+labor?
Seanam
Oct 4, 2015 10:15 AM
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
