clutch problem!!?
Old Nov 30, 2006 | 04:50 AM
FredP's Avatar
FredP
Default clutch problem!!?
ok i just got back from the tracks and seems as if my clutch is screwed from i dont know what so everytime i let go of the clutch while in first or reverse at times it wont stall... or when i get off doesnt seem to catch as hard as it used to i dont know whats wrong and if i do i get a new clutch does mlabor cost a lot to get it replaced or checked? or does the clutch cable need to be adjusted? and when i turn off my car smells kinda funny like burnt tire but a little more towards the front of the car
Old Nov 30, 2006 | 04:56 AM
FredP's Avatar
FredP
Default RE: clutch problem!!?
anyone?
Old Nov 30, 2006 | 05:05 AM
92hatchLX's Avatar
92hatchLX
let it cool down for a good long time, go out and drive it and see how it feels then. Were you at the drag strip or like a road course?
Old Nov 30, 2006 | 05:06 AM
FredP's Avatar
FredP
drag strip you think by cooling it down would help?
Old Nov 30, 2006 | 05:27 AM
92hatchLX's Avatar
92hatchLX
I'm no clutch expert, but maybe it's just really hot. Run it in the morning and see how it feels, you might have burnt it up. Has the clutch ever been replaced? Is it the stock clutch?
Old Nov 30, 2006 | 11:06 AM
shaners90lxhatch's Avatar
shaners90lxhatch
it sounds like its not engaging properly. if you can just let it out at a standstill and not stall as well as smell a funny burnt odor - it is cooking and not grabbing the flywheel. Many things can cause this. You could have a worn out pressure plate, the nose on your input shaft may be extremely gawled up and keeping the throwout bearing from returning.....I don't think you have an issue with the cable if I understand the situation properly. If the cable were binding or stretching, you would have an issue with disengagement. Perhaps if you write a more descriptive example of your problems, I/we could give some better advice.
Old Nov 30, 2006 | 04:20 PM
94gtcoupe's Avatar
94gtcoupe
it's most likely either hot to the point that it "shears" the clutch when you try to engage it or it's "glazed" from the launches (it you feather your clutch instead of dumping) let it cool down over night if that doesn't help then go to a parking lot and spend about and hour taking off and stoping (hopefully you can get it to "unglaze"
not a clutch expert but thats what happend to my stock one (couldn't save it by the way)
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
MasterLanMan
Sep 13, 2015 08:21 PM
Brandonfilipponi@yahoo.com
Sep 12, 2015 11:39 AM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
