lean adjustment
Old Nov 30, 2006 | 11:33 AM
iamvillani's Avatar
iamvillani
Default lean adjustment
so i replaced all my plugs last night, because when the motor is hot it won't start right up (cranks for about 2-3sec). So i noticed that every plus was not gapped correctly (.40) and every one was white. How do i fix this? Thanks.... i gapped each each plug at .54
Old Nov 30, 2006 | 12:11 PM
shaners90lxhatch's Avatar
shaners90lxhatch
Default RE: lean adjustment
well, you hit the nail on the head with the lean suggestion. It could be a management thing, it could be an issue with actual fuel delivery (injectors, filter, pump, et cetera). Are you running a 5.0 now, or a 2.3? I would start by checking fuel pressure. If you have a voltmeter, you can check your oxygen sensor voltages to see when it is running lean (top end only, or lean all the time). Lean contributor diag is a pain in the **** when you have the luxury of looking at PIDs (sensor values as the pcm sees them with a scan tool) let alone trying to figure it out without them.
Old Nov 30, 2006 | 12:43 PM
nitrous_bob's Avatar
nitrous_bob
if you are going lean, the last thing you want to do is open the plugs
your actually better with a gap of about .045" you don't really lose anything, but you keep a tighter spark
i would check your timing, you either need to drop timing back down to about 12* on 87 octane , or use premium all the time either way.
Old Nov 30, 2006 | 12:50 PM
iamvillani's Avatar
iamvillani
oh yeah i forgot to say that right before i replaced the plugs the timing was at like 5-6 degrees.....i put it back to 10-11...i just bought the car....would 5-6 degrees of timing make it lean?
Old Nov 30, 2006 | 01:27 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Do you only have this problem on warm restarts? And after it starts does it run ok or a lil rough at first?
Old Nov 30, 2006 | 01:56 PM
iamvillani's Avatar
iamvillani
yeah only after warm starts.....first start of the day starts really quick seems like no cranks just boom fires....and yes after it starts(warm) it runs fine
Old Nov 30, 2006 | 01:58 PM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Might wanna have a look at the ECT sensor.
Old Nov 30, 2006 | 01:59 PM
iamvillani's Avatar
iamvillani
k thanks ill try that
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Dathan
Oct 5, 2015 05:52 AM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
