Whatcha Think ????
Old Dec 6, 2006 | 04:22 AM
pony7up's Avatar
pony7up
Default Whatcha Think ????
I have a 90 vert and I am about to take it to a tune shop for my dyno results in a week . I was just curious what you guys think I can be putting out on horsepower with my setup ?
Here it is ..
Trickflow Stage 1 cam
Trickflow track heat intake
Granatelli 65mm Tb
moroso cold air intake
Granatelli 75mm mass air
24lb injectors
Frp 1.6 aluminum RR
ported Gt-40 heads
Fuel pressure regulaor set for 35 Psi
255lph fuel pump
BBk shorty headers
2 1/2 exhaust into a bassani X pipe into dual borla catbacks
on a stock block..
Any info would be greatly appreciated, Thanks
Old Dec 6, 2006 | 04:37 AM
nmerrill's Avatar
nmerrill
Default RE: Whatcha Think ????
260-280rwhp
Old Dec 6, 2006 | 04:41 AM
pony7up's Avatar
pony7up
Could it be possible to hit mid 13s with my 3.73s and some good slicks ?
thanks.
Old Dec 6, 2006 | 04:45 AM
87WSP5.0's Avatar
87WSP5.0
260rwhp
Old Dec 6, 2006 | 04:50 AM
vt89gtvert's Avatar
vt89gtvert
ORIGINAL: pony7up
thanks.
Put some money into you suspension and it could very easily do that. Subframe connectors, rear control arms, some strange ten ways, welded torque boxes, and a new K-member will go a LONG way.
Old Dec 6, 2006 | 04:52 AM
SteveSkal's Avatar
SteveSkal
Why 35 PSI on the fuel pressure? Stock is like 38? You'd want a little higher pressure for more power, not lower?
Old Dec 6, 2006 | 05:03 AM
pony7up's Avatar
pony7up
What fuel pressure should i set it at ? I was told that 35 was perfect for this car ! Should it be a little higher than 38psi ?
Old Dec 6, 2006 | 09:31 AM
7upedition's Avatar
7upedition
39psi here... +2 on suspension mods for track times, upper/lower control arms, springs/shocks, weld up the factory torque plates and get some wolfe products torque box plates, full length subframes, you'll get your 13 sec... GL
Old Dec 6, 2006 | 12:16 PM
gt884me's Avatar
gt884me
255 rwhp
Old Dec 6, 2006 | 12:24 PM
Jared_blown5.0's Avatar
Jared_blown5.0
I say 240 since no upgraded cam is in your mod list.
