quick question about 93 pistons
I know the things are hypereuctectic and cant handle boosts of any kind very well. I was wondering, can you simply swap pistons from an earlier 5.0 302 into the 93 or is the block different too?
It would be more of a hassle than it's worth. Either find another stock shortblock to swap or just do a full rebuild. I wouldn't put too much thought into the weakness of those pistons though. I've sprayed over 200hp on them for a long time. My friend put 10psi on them for 3 years until his warranty was expired on the blower. He then went to 16psi with it. The block split before the pistons gave out. They just don't like detonation. Bring enough fuel and don't worry about them.
ORIGINAL: 88BlueGT
So you think it will be OK to run a 100 shot with no tune on a 93?
BUT, I always replace the fuel pump if I even suspect it may be stock. Bring the fuel and spray it down.
ORIGINAL: FullAuto
I never put less than 150hp of nitrous on any 5.0 Mustang I get. Day 1 of ownership, no matter the miles, no matter the pistons, it doesn't matter. I'd put 150hp wet to a 250k hypereutectic motor and never think twice about it. 100 shot isn't even a test on those.
ORIGINAL: 88BlueGT
he is right, with a wet shot theoretically their is no limit to the added horsepower. only the limits of the engine are what stop you. I was lookin in summit and i saw keith black sil-o-lite pistons are only like 180 bucks for a .030 over set! but they are hyperutetic, after i saw that i went psh not for my motor. but after hearing you i am thinkin about it now.
ORIGINAL: Mowin8603
daaaamn! thast impressive! not sure that i would want to try it on my 5.0 but good to know.
I DO NOT RECOMMEND TO ANYONE TO SPRAY MORE THAN 150HP ON THEIR STOCK SHORTBLOCKS!!! Yes, your motor will take it without any issues. Yes, I would do it if I owned your cars. But if you are needing recommendations, then you probably don't have the experience to safely do it. You probably aren't familiar enough with tuning the systems. If you are fully capable of safely operating a 200+hp shot on your stock shortblock (because it WILL take it), then you wouldn't be asking for recommendations, would you?
ORIGINAL: musclemustang94
