Upper Control Arms Install
Old Dec 19, 2006 | 07:51 PM
Raphs50's Avatar
Raphs50
Default RE: Upper Control Arms Install
I did mine a month or so ago and had no problems accessing the bolts after I had the lower arms out and the drive-shaft disconnected. I replaced the bushings and that job was a royal pain, but getting the control arms out was not bad. If you do drop the rear-end more, you may want to disconnect the rear brake line where it connects to the under-body. Dropping the rear-end that far put a lot of stress on the brake line.
Old Dec 19, 2006 | 08:03 PM
dillon1340's Avatar
dillon1340
ORIGINAL: Raphs50
yeah i heard the axle bushing are a pain. i ordered a tool from 50resto that is supposed to make them easier to install and remove. the arms and the tool will be here thursday and i'm psyched
Old Dec 19, 2006 | 09:02 PM
Raphs50's Avatar
Raphs50
Yeah, I wish I had purchased the tool. I ended up making my own tool out of a C-clamp, a piece of flat steel, and a large socket. It worked but I spent about 2 hours getting the bushings out. Good luck with it.
Old Dec 19, 2006 | 09:37 PM
dillon1340's Avatar
dillon1340
Awjeez. any helpful hints you can give? i really don't know what is involved. is it difficult because of access? or is it difficult because it's pressed in there?
Old Dec 19, 2006 | 09:40 PM
tom50's Avatar
tom50
nm
Old Dec 19, 2006 | 09:44 PM
Raphs50's Avatar
Raphs50
I had the whole rear end out of the car, so access wasn't a problem. It was difficult because it was pressed in and had been in there for 20 years. If you have the tool you should be OK, just be patient. Once I got them broken free, the rest wasn't too bad, and putting the new ones in was easy.
Old Dec 19, 2006 | 09:46 PM
Raphs50's Avatar
Raphs50
I may need to reinforce my torque boxes also. Check out this link. It has pics and instructions.
http://www.mustang50magazine.com/howto/35618/
Old Dec 19, 2006 | 09:57 PM
dillon1340's Avatar
dillon1340
good link. i think those 'battle boxes' are like $174 though.
http://www.latemodelrestoration.com/...1&comp=LRS
Old Dec 19, 2006 | 10:13 PM
Raphs50's Avatar
Raphs50
Yeah, I just looked on 50resto also and was surpised they were so much $$$. $175 seems a bit pricey. [:-]
Old Dec 19, 2006 | 11:51 PM
dillon1340's Avatar
dillon1340
i might just do what was listed above and weld up the seams. found this link in another post:
http://www.mustangmotorsport.com/boxes.html
