Eibach
Well plans have changed the website I was checking out had a misprint and I can't get 1" drop on Ford's G Lowering Springs for Vert's sooo I have to buy eibach's spring kit #EIB-3514, any suggestions on cheapest place to place the order? Ebay seller name or website? They are around $240 vs. the $150 from Ford Racing... bastards![:@]
TIA[8D]
TIA[8D]
TIA=thanks in advance
X2 on the H&R springs. A couple of guys locally say that their Eibachs started to sag after a few years. H&R's springs are supposed to be some of the highest quality springs you can buy, and they're ~220ish.
If you're looking for the 1" drop, go w/ the Super sports. They have a tighter spring rate than the Sports, also. ....Be sure to change your shocks/struts--stockers won't like those springs much
i had eibachs and didn't like the ride at all
if you run on smooth roads you might be ok
rolling on something that isn't smooth there were not kind to me
the fords were much better, you will have to have up graded shocks
or you will have real problems .....................
think of all the springs i have tried the mac's rode the best of all of em
next up is a set of bullitts
Any links to the H&R Super Sport Springs, I am going with tokico HP shocks and struts (i'm 99% sure) was going to go adjustable but not really neccesary for my setup. From my understanding you need different springs for the vert cause of the extra weight in the rear. Thanks Guys
