electrical issues
so i just got a new bbk 155lph fuel pump installed a week ago, and i went to pick my car up from the mechanics. i got in it and it started up fine, then i drove it 1/8 mile down the road and it just completely died and would not start. so i had some people push me, i popped the clutch and it started fine. before i put the new fuel pump in, it was having problems starting and it would just stall out when i was driving, and not start again for sometimes a whole day. i thought the fuel pump would solve the problem but obviously not. you guys have any idea what is goin on?
when it died out on you, and you tried to start it, Did it crank over at all?
If it wouldnt crank, I would check the starter solenoid, then the starter itself.
If it WAS cranking, but wouldnt start. I would replace the ignition module on the side of the distributor!
TFI modules are known to be bad out of the box. get one from your local ford dealer and try again. If it still does not solve your problem, you may need to replace the pickup coil in the distributor
mrappe
Sep 26, 2015 10:16 AM
