Accelearation rattle
Old Dec 27, 2006 | 03:50 AM
  #21
whiteout 5.0's Avatar
whiteout 5.0
Default RE: Accelearation rattle
lol 10 bucks says the rattle he hears is an exhaust leak around the header
Old Dec 27, 2006 | 05:24 AM
  #22
sm6989's Avatar
sm6989
I know I have an exhaust leak but this sounds nothing like an exhaust leak
Old Dec 27, 2006 | 04:32 PM
  #23
Gtdaniel's Avatar
Gtdaniel
its your timing, It just happend to me when I advanced it,its the same sound your describing,I just back the timing down a hair,I didnt use a timing light though. I backed it down till the rattling noise went away,but now I'm back where the timing was.but thats ok I wouldnt want to blow my engine.
Old Dec 28, 2006 | 07:47 PM
  #24
sm6989's Avatar
sm6989
Lowered the timing, Put seafoam in it..and higher octane still making the rattleing noise.. now that I listen it acutally sounds like its comeing from underneath..more towards the front.(cat location)
Old Dec 28, 2006 | 07:53 PM
  #25
mattdel's Avatar
mattdel
you still have stock cats? they're probably junk. the honeycomb inside is rattling around because its broken apart. lay under the car and tap on the cats with a wrench or small hammer, you'll reproduce the noise almost perfectly if the cats are the problem.
Old Dec 28, 2006 | 08:11 PM
  #26
20yrNotch's Avatar
20yrNotch
maybe its his motor mounts, they could be lose?
Old Dec 28, 2006 | 08:12 PM
  #27
mattdel's Avatar
mattdel
motor mounts generally cause a vibration or ton's of body flex, not really rattles
Old Dec 28, 2006 | 10:36 PM
  #28
sm6989's Avatar
sm6989
I know its not the motor mounts...Im afraid to go banging on the cats, dont want the sound to get worse lol...
Old Dec 29, 2006 | 12:48 PM
  #29
aode08's Avatar
aode08
jack the car up and bang on your converters with a rubber mallet and listen, also check the welds on all your cats shields and any traces of black carbon from the exhaust indicating a leak.when mine did that, I looked and seen someone put a rag in between a heat shield on the converter that lost two of its welds to rust.
I wouldnt drive
Old Dec 30, 2006 | 02:43 PM
  #30
sm6989's Avatar
sm6989
What you mean you wouldn't drive? The sound doesnt seem to be as bad anymore, I messed with the timing more then gave a couple taps on the cats. Still makes the sound but very little. I only hit thecat on the left side so I think it may have cleared that one up(for now lol), Cause you can hear the noisemainly just onthe right now..so guess its those.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
UrS4
Sep 30, 2015 10:13 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
movielover40
Sep 15, 2015 10:37 AM
tmdm
Sep 4, 2015 06:45 PM
