fuel pressure regulator
Old Dec 28, 2006 | 07:35 PM
fast86capri's Avatar
fast86capri
Default fuel pressure regulator
just put a bbk fuel pressure regulator in my car i was just wondering if it is bad to raise the fuel pressure to much and what would be good fuel pressure.
Old Dec 28, 2006 | 07:47 PM
93must's Avatar
93must
Default RE: fuel pressure regulator
the stock fuel pressure if you car is stock 39-41psi! If it is getting to much fuel could cause a number of dif problems. poor fuel economy, pre detination, hesitation, and mess up your sensors.
Old Dec 28, 2006 | 07:52 PM
Gtdaniel's Avatar
Gtdaniel
so what do you need to check if you have the correct psi?
Old Dec 28, 2006 | 08:02 PM
dillon1340's Avatar
dillon1340
need to have a fuel pressure gauge. you can mount one on the pressure port on the return line
Old Dec 28, 2006 | 08:29 PM
vt89gtvert's Avatar
vt89gtvert
I think he is asking what would be a good pressure to set it to. I think (I don't know) but it would be a good idea to give the guys who might know this one a list of your mods so they have a better understand of how you car is setup
Old Dec 29, 2006 | 01:51 AM
vristang's Avatar
vristang
Always start with stock pressure.
Getting the pressure too high will cause fuel metering problems. Up to about 50psi should be ok, anything over that will cause problems for the injectors.
Start with stock, and adjust from there.
Summit carries fuel pressure gauges that mount on the shraeder valve of the factory fuel lines.
This is very handy to have under the hood.
jason
Old Dec 29, 2006 | 01:57 AM
92hatchLX's Avatar
92hatchLX
Leave it at stock until you can get it on a dyno.
Old Dec 29, 2006 | 02:00 AM
Ninety5five0's Avatar
Ninety5five0
I believe stock pressure is 38 pounds, and there really isnt much of a need to up the pressure too high unless its needed.
Old Dec 29, 2006 | 02:09 AM
nitrous_bob's Avatar
nitrous_bob
you'll slow down if you go too high. and you probably don't need to.
stock should be 42 psi W/ THE VAC LINE REMOVED
i have seen guys pick up a noticible gain by leaning out to about 35-36 psi (w/ vac on at idle)
mrtrodonet
Sep 19, 2020 03:12 PM
Sixx
Oct 5, 2015 07:36 PM
svfetter
Oct 5, 2015 11:39 AM
88 orangepeel notch
Oct 5, 2015 09:03 AM
mrappe
Sep 26, 2015 10:16 AM
