Problem with the heater...please help
Old Dec 30, 2006 | 02:37 PM
88 GT n loven it....'s Avatar
Default Problem with the heater...please help
hi as i was saying i have a problem with my 88 mustang GT it's a 5 speed if it helps, so getting tothe point is that whenever I turn on my heater the car doesnt throw the air hot it throws it even colder than how the weather is any one has any idea on how to fix this any suggestions would help....thanks
Old Dec 30, 2006 | 02:42 PM
mattdel's Avatar
mattdel
Default RE: Problem with the heater...please help
low antifreeze and/or air in the system
5.0stanger's Avatar
5.0stanger
How does you hear control **** turn? easy? spin all the way around? It is hooked to a cable, check to make sure it issliding when you turn the ****.
Old Dec 30, 2006 | 02:45 PM
the **** does work proporly since i changed it b/c it was broken and after i changed it it only goes all the way to the red part and only half way to the blue side which is cold .....lol
Old Dec 30, 2006 | 02:49 PM
5.0stanger's Avatar
5.0stanger
Get under the dash and chexck the cable.
Old Dec 30, 2006 | 02:50 PM
mattdel's Avatar
mattdel
if it only goes halfway to the blue side, that means when your fully turned to the red side, its ACTUALLY only about halfway to the end... see what you can do to adjust it
Old Dec 30, 2006 | 03:54 PM
deanzawistowski's Avatar
deanzawistowski
i though tmy heater was broke but it turns out there was a 160 degree thermostat in there, i out in a 190 in problem solved
Seanam
Oct 4, 2015 10:15 AM
69Volunteer
Sep 30, 2015 10:39 AM
marc954
Sep 29, 2015 03:05 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
