Block question
Old Jan 3, 2007 | 02:22 AM
ncplaya88's Avatar
ncplaya88
Default Block question
The motor in my 1992 ford mustang, will the block hold up to a 331 build, trick flow top end kit with a mild cam?
Old Jan 3, 2007 | 02:25 AM
iceman89gt's Avatar
iceman89gt
Default RE: Block question
if the block is prep. right i dont see why not. im a beleiver in seasoned blocks. it just needs to be prepared by a good knowledgable person.
Old Jan 3, 2007 | 02:26 AM
89Ford's Avatar
89Ford
yea it will be fine
Old Jan 3, 2007 | 02:35 AM
Li0nHart's Avatar
Li0nHart
i thought you needed the older block with the thick webbing to avoid splittign the block..i think it was early 70's era...
Old Jan 3, 2007 | 02:37 AM
iceman89gt's Avatar
iceman89gt
not really, i see them at the track running 347s with no problems spray and all
Old Jan 3, 2007 | 02:47 AM
89Ford's Avatar
89Ford
he didnt say anything about how much hp he is expecting so I only said it would be fine, as long as he stay in the safe number some between 300-400hp i believe it is
Old Jan 3, 2007 | 05:10 AM
gspfunk's Avatar
gspfunk
Assuming you aren't running a power adder, you probably aren't going to crack that block w/ an N/A application....usually don't see power levels high enough. FYI, 450-500 rwhp on a safe tune is all the block is good for.
Old Jan 3, 2007 | 06:21 AM
w8less's Avatar
w8less
it will be fine in motor trim but if u get a supercharger it might look like this
[IMG]local://upfiles/12612/AFD1F20552714623A6B4CE36D0AD1A31.jpg[/IMG]
Old Jan 3, 2007 | 12:33 PM
88BlueGT's Avatar
88BlueGT
+1 to everything posted above. You will be more than fine. A setup like that is only going to put you around 350rwhp.... you could run a SC with that if you wanted to. Just not tons of boost.... or a small shot
Old Jan 3, 2007 | 05:08 PM
Nadelle's Avatar
Nadelle
stock 5.0 block is good until about 450hp
