Underdrive pulley help!!!!!!!
Old Jan 4, 2007 | 07:39 PM
MOhecan's Avatar
MOhecan
Default Underdrive pulley help!!!!!!!
i jus installed the underdrive pulley for my 91 mustang. i didnt install the alternator pulley cause alot of people on here said not too. but the factory belt is to big. what size belt do i need?????
Old Jan 4, 2007 | 08:04 PM
mattdel's Avatar
mattdel
Default RE: Underdrive pulley help!!!!!!!
which one(s) did you use
Old Jan 4, 2007 | 08:10 PM
MOhecan's Avatar
MOhecan
water pump and crankshaft they are bbk underdrive pulleys
Old Jan 4, 2007 | 08:16 PM
mattdel's Avatar
mattdel
what part number is on the box
Old Jan 4, 2007 | 08:17 PM
MOhecan's Avatar
MOhecan
1513
Old Jan 4, 2007 | 08:22 PM
notch5oh's Avatar
notch5oh
are u replacing the belt at the same time? i did when i did my pullies and the factory replacement belt i got was too big, someone told my a/c compressor had been replaced with a newer style at some point and it took the next size down
i doubt thats your problem but i thought i'd throw it out there
mattdel's Avatar
mattdel
according to the install instructions the stock belt fits.
Old Jan 4, 2007 | 08:25 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
it does when you use the alt pulley..
MOhecan's Avatar
MOhecan
i havent repalaced the ac. but when u go to get the belt u have w/o air, factory air and dealer air. i tried factory and i think w/o and the dealer air belt is inbewtween them in sizes. so i think i might try that. but i was right not to put the alternator pulley on right?
Old Jan 4, 2007 | 08:26 PM
mattdel's Avatar
mattdel
The BBK Street Pulley Kit is designed to increase power by reducing the overall speed of the serpentine
system, and should in no way create a charging or cooling problem. However, an examination of
the fan clutch, thermostat, and radiator should be performed to insure proper operation. (Cars
equipped with high drawing aftermarket sound systems should check charging effectiveness before
installation of underdrive pulleys.)
