Gimme head
Old Sep 23, 2004 | 12:28 PM
FoxGT's Avatar
FoxGT
Default Gimme head
Can I just take these 5 bolts off & pull the head straight off? Or do I have to worry about some part shooting into my eyes?
[IMG]local://upfiles/1583/56C0DC112A1E4902A55114A4E22DD13C.jpg[/IMG]
Old Sep 23, 2004 | 01:01 PM
StangMang's Avatar
StangMang
Default RE: Gimme head
you gotta take off the rockers and valve springs
Old Sep 23, 2004 | 01:29 PM
roundman's Avatar
roundman
WRONG, WRONG, WRONG!!!
all you got to do is loosen the rocker arms to take the tension off the valve springs and then you have another 5 bolts down low adjacent to the spark plugs. you didn't really think the head was held on with only 5 bolts did you? and you do know that the 5.0 uses torque to yield head bolts so once you remove them, you need to replace them with new ones! if you get the good ones from ARP, you can reuse them as often as you like, but stock ones are only good for one time usage!
Old Sep 23, 2004 | 01:33 PM
StangMang's Avatar
StangMang
i knew that roundman...just waited to see if someone would catch on....GOOD JOB...you pasted the test[sm=smiley32.gif]
Old Sep 23, 2004 | 01:47 PM
FoxGT's Avatar
FoxGT
ORIGINAL: StangMang
You're evil. What if I woulda went & took them off right after you posted?
Old Sep 23, 2004 | 01:52 PM
StangMang's Avatar
StangMang
ORIGINAL: Isaac
ORIGINAL: StangMang
Truthfully...nothing bad would of happend
Old Sep 23, 2004 | 04:25 PM
90LX50's Avatar
90LX50
ORIGINAL: StangMang
ORIGINAL: Isaac
ORIGINAL: StangMang
Uhm, o.k., i think it would've sucked for him, valves falling all over the place. that's my kinda fun, and luck.[&:]
Old Sep 23, 2004 | 05:22 PM
619socalstang's Avatar
619socalstang
Uhm, o.k. , i think it would've sucked for him, valves falling all over the place. that's my kinda fun, and luck.
???????????????????????????????????????? i dont thin so???????????????????????????????????????????????? ???
Old Sep 23, 2004 | 05:35 PM
FoxGT's Avatar
FoxGT
I'm suprised they didn't fall apart anyway. I have horrible life luck, but in games my luck is really good. I wish I could transfer the game luck to life.
Old Sep 23, 2004 | 10:46 PM
90LX50's Avatar
90LX50
ORIGINAL: 619socalstang
If he took the rocker arms and the springs off, and then pulled the head off?? you better check again pal, once you compress the springs and pull the retaining clips, there ain't nothing left to hold the valves in place, unless you have magical heads.
I might be new to the board here, but not to cars or V8's
