Not Charging? (Need Help)
I was driving my 87 Mustang GT and all of a sudden the amp light came on and I noticed that my battery guauge was in the red, needless to say the car didn't start up once I turned it off.
I had my bro look at it, he found that the starter bolts were loose. He fixed that. He also replaced the alternator, but the car still doesn't hold a charge.
I have heard that these mustangs have had issues with holding a charge. He has checked all the wires. He is also going to look at the schematics.
Is there anything he or I should be looking for?
Swirl
Swirl
Here are a few ideas, make sure you load test the battery, could have a dead cell, check the voltage regulator for voltage output, third, check and make sure all your grounds and connections are clean, hooked up and tight, engine grounds and cables going to the battery.
if it's not holding a charge....it's the battery
car off, batt should be about 12.0-13.0 volts
test the battery while the car is running and should be putting out about 13.5-14 volts to show the alt is good
[:@] oks here it is i had the same problem with mine 90 lx 5ohh my batt light used to come on i changed my batt and a new alt still[:@]HAD PROBLEM so i checked at the starter solenoid there check this pic follow those wires down and it will lead you to your problem
[IMG]local://upfiles/58303/BF6F4AE314ED428FB5F528AC00C249A8.jpg[/IMG]
ORIGINAL: 5.0stallion
Thanks for the picture.
Swirl
before you go putting another alt in check to make sure its putting out right should be around13.5 to 14 volts could very well be your voltage regulator might as well get a new one wouldnt hurt
