harmonic balancer
how do i remove the harmonic balancer? i tool the bolt off and the water pump but i cant seem to get the balancer off is there any tip on getting it off?
you didnt need to pull the water pump. you gotta unbolt the pulley from the balancer, 4 bolts, allen(hex) key needed for removal. buy a puller from autozone. when reinstalling, tighten all the way down until the bolt wont turn anymore.
ORIGINAL: mattdel
+1, make sure teh washer is out. Pullers are like $14 at Autozone, it's easy. When putting it back on put some white engine grease on the walls of the area the crank fits in, and line the keyway with some black RTV. Torque the bolt to 70-90 ft/lbs
ORIGINAL: mattdel
