funny clutch
Old Jan 9, 2007 | 02:34 PM
littlebluelx's Avatar
littlebluelx
Default funny clutch
I put a used tranny in it only had 12,000 miles on it in yesterday.I also had to replace my clutch cable again, this cable was the same lenth as the one I pulled out.
My problem is mow I only push my clutch down 2 inches and it is fully engaged anythig past thet length its soft. befor(old cable)I had to push it half way down to get it to engage.
What Happened Or What Did I Do Wrong?
It is a King Cobra clutch, and stock cable.
Thank you,
William
Old Jan 9, 2007 | 02:42 PM
94gtcoupe's Avatar
94gtcoupe
Default RE: funny clutch
well first of all when you push the clutch pedel it's DISengaging the clutch (just a lil FYI)... not being a ***** but using the right terms makes it easiers to help you... but the only thing i can think of thatt might be wrong is the plastic clutch quadrent
Old Jan 9, 2007 | 03:09 PM
littlebluelx
sorry about that, and I also don't take that as you being a ***** just helping. This is my first standerd so I am learning.
So could i have routed the cable wrong on the quadrent or is the quardernt itself going wrong.
Old Jan 9, 2007 | 03:44 PM
90Lxstanger's Avatar
90Lxstanger
Yeah, you might wanna consider gettingan aftermarket clutch cable/quadrant/&firewall adjuster b/c you have a aftermarket clutch, and the stock cable might now work the best. Hope you figure it out.
Old Jan 9, 2007 | 03:59 PM
P Zero's Avatar
P Zero
Did you use the self adjuster? Pull up on the clutch pedal until it clicks, this is the self adjuster. Itll automatically slacken the clutch cable for you. You might hear a loud pop you might not. I have run several super heavy duty clutches with my stock quadrant on several cars and never had a problem. In fact they worked so well, wound up getting spider cracks in 2 flywheels big enough to see light through. Aftermarket quadrants are for people that cant figure out how to use the stock one[8D].
-P.
Thunderball
15
Nov 22, 2015 11:49 PM
junior04
Sep 28, 2015 10:53 AM
MacSerio
Sep 27, 2015 01:05 PM
stangin1996gt
Sep 21, 2015 11:01 AM
