gasket question
I am putting my new 65MM throttle body on tommorow. When I ordered my gaskets from Advanced Auto today they had no idea how to look then up since everything in their computer is by make, model, year, and the like. So finally I tell then that the 93 cobra had a 65mm TB, and they ordered them based one that. This will work correct????
As far as bolt patterns lining up you are good. As for the ID of the gasket matching the ID of the TB(65mm) I believe it should work. If not the gasket should be easy to sand a little off the inside to make it 65mm
you could order some from summit and places like that but if anything just get sum gasket material i know they will have it there, and make it yourself. its not like we are talking about a head gasket here
treesloth
Sep 28, 2015 07:03 AM
