New build
Old Jan 13, 2007 | 11:43 AM
stanglx2002's Avatar
stanglx2002
Default New build
My 331 is downing so oil about 2 - 2.5 quarts every oil change not good. So I decided its time fora new build. Im getting a 98 explorer motor with 55,000 miles on it from my uncle for $650 complete. Here are my plans for the engine nothing ratical since its a DD. I want to keep the compression ratio at 9:1 so if I add a turbo later I can.
Complete engine rebuiuld kit - Federal Mogul standard bore or maybe a .30 bore with new pistons
Hone and bath the block
Have the pistons cleaned
Balanced and Blueprint the shortblock
Trick Flow Stage 1 Cam
Now for the Heads - GT-40P:
Ported and polished
Either a 3 or 5 angle valve job
New Trick flow spring kit and new valves and seals
Gasket match the intake and exhaust ports
1.6 RR
Now for the Intake:
Port and polish it
gasket match to felpro 1250
increase runner #5 for better flow
Increase TB port to 70mm
This all going to be put together with all new ARP bolts. I rest of my combo is going to be #24 injectors, 70mm TB with 70MM EGR delete plate, 1" intake spacer, Ford Racing Tall VC's, 2 breathers, mini starter, 76mm MAF and Inlet Tube, Mac 1 5/8 headers with locking header bolts, 2.5o/r h-pipe, Dynomax ultra flow mufflers. New timing chain, waterpump, and PS pump.
I hoping for at least 300 rwhp with this combo but we will see. Tell me what you guys think.
Old Jan 13, 2007 | 01:27 PM
92GreyGT's Avatar
92GreyGT
Default RE: New build
The oil consumption problem isn't with the heads you have on your 331 is it? The short block could be just fine and the problem be in the valve guidesor maybe just valve stem seals.
Old Jan 13, 2007 | 01:33 PM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: 92GreyGT
+1 especially if your seeing oil on startup
Old Jan 13, 2007 | 02:19 PM
stanglx2002
I have always wanted to go back to a 302 bc the 331's dont last as long. Im going to sell my 331 to my friend or part it out. I cant afford to lose my car to fix the heads if thats the problem also I dont think thats the problem anyways I think the oil is seeping past the rings anyways.
But besides that what do you guys think of the new build
Old Jan 13, 2007 | 11:29 PM
stanglx2002
Old Jan 14, 2007 | 12:15 AM
stanglx2002
Im hoping to have the build done this summer or fall. Im thinking the build should net 300 rwhp
Old Jan 14, 2007 | 05:01 PM
stanglx2002
Do you guys recommend anything else for this build?
svfetter
Oct 5, 2015 11:39 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
the5
Sep 19, 2015 06:13 PM
2015Ecoboost
Sep 17, 2015 01:48 PM
rksnow1
Sep 14, 2015 08:46 PM
