I made 300rwhp w/TFS kit dyno sheet
Hey guys like I said I made 300rwhp w/ the TFS Street Heat top end kit on a 302 w/ an AOD.
Here is everything on my car:
92 Mustang LX
AOD Trans
2800 stall converter
4.10 gears
TFS Street Heat (Heads, Cam, Intake)
New Lifters
Basssani Shortie Headers
Bassani OR Pipe (but i am gonna switch to a catted pipe)
Bassani Catback
70mm TB
95mm mass air meter
3 1/2 N.A. Powerpipe
30lb injectors
Under Drive Pullies
Any thoughts what I would run in the 1/4 (street tires, stock suspension)?
Also will a catted pipe rob much power?
[IMG]local://upfiles/37162/BB14E5D96FB240A7B51188A50E9881C7.jpg[/IMG]
92 Mustang LX
AOD Trans
4.10 gears
New Lifters
Bassani Catback
70mm TB
95mm mass air meter
30lb injectors
Under Drive Pullies
With a set of drag radials and some upper and lower control arms you will be deep in the 12s. I was making 288 at the wheels with a 5 speed and running 12.50s all day long with good traction.
Nice work.
You should work on your suspension next to get that power to the ground. Stock suspension isn't too great. At least get some U/L control arms and subframes. Your stock springs and shocks/struts w/ street tires will limit your traction alot as well.
ORIGINAL: gspfunk
Nice work.
Nice work.
ORIGINAL: BlackLX
It's about time someone gets some nice numbers with the Trick Flow kit. I was getting tired of seeing people only get 275rwhp out of it.
