tsat
guys my car is funny first when it drives on the highway for a while with the heat on the needle for h20 temp goes right to H
should i just take out hte tstat, or is it somethin, the coolant to water mixture is like 50-50 so
We'll first thing i'd do is try to birp the system, maybe an air bubble causing a bad reading. Next look into a new tstat (180*) DO NOT leave the tstat out. The car needs to run at around 190-210*. While changing the tstat do a flush n fill with new coolant and verify the 50/50mixture with a tester. Birp the system real well and test drive. Chances are the tstat is shot.... thats why i'd recomend a failsafe brand from autozone. Good Luck and don't drive the car with the temp that high!
the tsat is new and i buped the system as i put new coolant in, the thing i thought was that since its cold there should be more coolant in there, but the tstat is 180 and its new, do u think that there might be too much sealant in the hose that may be cloggin it up
the sealant in the hose where the new tstat went
ORIGINAL: 7upedition
more coolant in the winter isn't better... you need 50/50 mix , what do you mean by sealant in the hose?
