installing timing chain cover need help!!
Old Jan 17, 2007 | 07:26 PM
blk89lx's Avatar
blk89lx
Default installing timing chain cover need help!!
ok im installing my new timing chain cover and my ? is do i need to use any sealent on the gasket or can i just bolt it up with just the gasket?
Old Jan 17, 2007 | 07:30 PM
nmerrill's Avatar
nmerrill
Default RE: installing timing chain cover need help!!
I just bolt mine up with the gasket, i havent had a problem yet
Old Jan 17, 2007 | 07:32 PM
shaners90lxhatch's Avatar
shaners90lxhatch
Throw the gasket away and use a 1/4 bead of black RTV around the whole edge of the cover. DO NOT PUT ON TOO MUCH. just a 1/4 bead --- (that thick) will do. Let it dry for at least 24hrs in 50f degree air before you start it. The gasket does not seal well with RTV and does not seal as well as RTV.
Old Jan 17, 2007 | 08:10 PM
94ford5liter's Avatar
94ford5liter
I put permatex on both sides on the gasket when I put my car back together recently, let it dry and everything, and it started leaking immediately when I filled the car with coolant lol. So you should either try a dry gasket or do what the guy above says to do.
Old Jan 17, 2007 | 08:17 PM
turbosha's Avatar
turbosha
like ive said before hang the gasket up in the shop and use black rtv. i have a old honed out balancer to locate the timing cover, works good
Old Jan 17, 2007 | 08:19 PM
AdderMk2's Avatar
AdderMk2
Banned
The best stuff to use is High Tack gasket sealant... if you cost the whole thing evenly, and let it haze over before assembling, it will never leak unless you leave a few screws out..
[IMG]local://upfiles/26017/AEBE4EBC9941477884D82E064BFEB011.jpg[/IMG]
94ford5liter
i think no matter what it is a pain in the ***, especially when you rip the oil pan gasket like I did haha.
Old Jan 17, 2007 | 08:21 PM
turbosha's Avatar
turbosha
the high take is some good stuff, till it has to come back apart, lots of scraping
Old Jan 17, 2007 | 08:22 PM
nmerrill's Avatar
nmerrill
ORIGINAL: AdderMk2
I have heard good things about this stuff also. Trick flow recommends using it on some of their products
Old Jan 17, 2007 | 09:21 PM
JeffUtica's Avatar
JeffUtica
ORIGINAL: AdderMk2
+1
