3g alt conversion!
im very close to finishing the installation and im a little confused about where the thick 4 awg wire goes. is it ground or power? is it best to put it on the battery or the starter solenoid? oh and where exactly is the starter solenoid? thanks
ORIGINAL: elmustang5.0
im very close to finishing the installation and im a little confused about where the thick 4 awg wire goes. is it ground or power? is it best to put it on the battery or the starter solenoid? thanks
You also need to upgrade your main grounds.
run a 4g cable in addition to the factory negative cable to the same location on the block
next to oil press. sending unit.
then run a 4g cable from the other side of the block using an exsisting bolt hole behind the smog pump
to the frame rail on the passngr side, right next to fuel vapor canister.
make sure all areas are cleaned to nice bare metal.
HRnB
GT350 S550 Tech
Dec 18, 2015 09:35 AM
Nov 10, 2015 11:39 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
