CLUTCH CABLE QUESTION PLEASE HELP
im installing my bbk CABLE KIT, CLUTCH, ADJUSTABLE, W/ QUADRANT AND FIREWALL ADJUSTER
i was wondering if you guys know if im doing this right http://i75.photobucket.com/albums/i3...0120071606.jpg that rubber gromet goes over the end of the cable and then the adjuster goes over it right? because its not letting me do it with out modifing it |
RE: clutch cable question please help
don't know but would like to know also just bought the same stuff,sorry no help
bump for my pal, i'm a tad impaired right now and cannot think[sm=alcoholic.gif][sm=partyparty.gif]
Impaired? Honestly, I'm not as think as you drunk I am!
Vic |
RE: CLUTCH CABLE QUESTION PLEASE HELP
well its getting dark and i got pissed so i cut the F ing thing
http://i75.photobucket.com/albums/i3...0120071653.jpg |
My Steeda kit had a different rubber grommet and it said to just take it off completely..... You should be fine the way you did it.
take the rubber off completely, it will infact make it more difficult to adjust it if its still on there...
There should also be 4 small plastic nubs on the white piece that will need to be trimmed to get the adjuster over it |
welll i got it all hooked up i dont know if i have it adjusted right i just know that the clutch pedal is hella stiff now
it shouldnt be stiff at all... and you really should remove that rubber
[align=left]u think the rubber is causing it to be stiff or its not adjusted right?
[/align][align=center] [/align] |
