MM suspension setup.. what do u all think?
Coil-Over Package, 1994-04 Mustang
Our Coil-Over Packages include the following parts:
[ul][*]MM Front Coil-Over Kit[*]MM Rear Coil-Over Kit*[*]Pair 2-1/2” Hypercoil Springs[*]Pair 2-1/4” Hypercoil Springs[*]Bilstein HD Front Struts[*]Bilstein HD Rear Shocks[*]MM Caster/Camber Plates**[/ul]
Fits 1994-95 Hard Top.
This Chassis Brace Package includes the following parts: [ul][*]MM Strut Tower Brace[*]Four-Point K-Member Brace[*]Full-length Subframe Connectors (bare steel)[/ul]Torque Arm Suspension System, 1979-98 Mustang, Standard Duty
This Torque Arm Package includes:
[ul][*]MM Standard Duty Torque Arm[*]MM Panhard Bar[*]MM Heavy Duty Non-adjustable Rear Lower Control Arms[/ul]im big on Maximum Motorsports... from what i hear the are the best... and thats what im goin for... this is a lotta money for this setup tho... what do i need and what dont i need.... honestly wat im goin for is being able to out handle a porsche on hte street and be able to adjust a few things the few times i feel like goin to the track... it this goal is to high tell me know plz... also i reliase some of it is the driver which is understandable... also i know tires matter... im gettin some bfg t/a kdw on 18in saleens... tell me if u think im gettin to much or not a enough... just give you opinion on the setup.. it will probably run a lil over 3 grand for all that listed above...
I don't think you can go wrong with that setup but it seems a bit over kill. I think you would be happy with some springs, shocks/struts, subframes and control arms. You'd be suprised how much better the car would handle.
ORIGINAL: ZachW04Stang
Those kits are great, but costly, if you have the dough and desire buy it... you won't regret it I can assure you that! Maximum Motorsports is a benchmark in quality for handling and quality built/performaning products. Good Luck
[sm=gears.gif]
[sm=gears.gif]
what about just this one package instead of the three different one.. it has mostly everything.. few diferences but u get a lil more for a lil less...
Fits 1994-95 Mustang
The Road & Track Box includes the following parts: [ul][*]MM Strut Tower Brace[*]MM 4-Point K-Member Brace[*]MM Full Length Subframe Connectors[*]MM Panhard Bar with Aluminum Rod[*]MM Heavy-duty Rear Lower Control Arms[*]MM Road & Track Springs[*]Bilstein HD front struts[*]Bilstein HD rear shocks[*]MM Caster/Camber Plates[*]MM Urethane Pinion Snubber[*]Front spring isolators[*]Rear spring isolators[*]Solid Steering Shaft[*]MM Aluminum Rack Bushings, center drilled[*]Front Swaybar bushings[*]Front Swaybar end link bushing kit[*]Front control arm bushings, urethane[/ul]
Talk about alot of work man.... your gonna have FUN!!!!!!
Anyway, I have heard really good things about that kit and would prob be a better buy... a little more bang for the buck.
