G-Force T-5!
Old Jan 24, 2007 | 12:48 AM
Scout2232's Avatar
Scout2232
Default G-Force T-5!
So I just bought a G-Force T-5 kit! Just thought I would let you all know! Can't wait to get my new shifter, clutch, and tranny in! I'll update this when I get it put back in and running and give you the lowdown on how it went.
Old Jan 24, 2007 | 02:09 AM
94gtcoupe's Avatar
94gtcoupe
Default RE: G-Force T-5!
should be a fairly easy project... break that tranny in the right way
Old Jan 24, 2007 | 02:11 AM
AdderMk2's Avatar
AdderMk2
Banned
I dont know if Len agrees with me, but with a brand new transmission, I would probably break it in much like a new engine... Change the fluid after like 500-1000 miles to flush out any particles that might break loose during break-in
Old Jan 24, 2007 | 02:14 AM
94gtcoupe's Avatar
94gtcoupe
yea keith i agree, change the fluid between 500-1000 miles, and then again at 3000...use non synthetic oil for the first 3000 miles, after that use synthetic...
i'm going to try a different kind of fluid and i'll let you guys know how i like it
Old Jan 24, 2007 | 02:31 AM
musclemustang94's Avatar
musclemustang94
Ford reccomends auto tranny fluid for the T5. Do they make a synthetic auto tranny fluid? I have only heard of ATF (mopar) Mercon (Ford) and Dexron (GM). And then the crap that imports use. Honda or Toyota or whatever brands.
Old Jan 24, 2007 | 02:32 AM
AdderMk2's Avatar
AdderMk2
Banned
Redline and Royal Purple, There is also GM synchromesh
Old Jan 24, 2007 | 02:33 AM
musclemustang94
Oh i see. Do you think if I tried that in my T5 it would quiet it down at all? I heard synthetic oil does magical things.
Old Jan 24, 2007 | 02:37 AM
AdderMk2's Avatar
AdderMk2
Banned
probably not... your more than likely getting a bit of bearing whine. Some trannies will whine forever, some will give out the next day.
Rebuild it with DDperformance upgrade parts, or go G-force... remember to get all new bearings. 1st and 3rd usually whine the most
Old Jan 24, 2007 | 03:51 AM
94gtcoupe's Avatar
94gtcoupe
i agree with adder there prolly is bearing bear, but synthetic fluid will help slow down any damage that is already there from getting worse
Old Jan 24, 2007 | 04:10 AM
larsif's Avatar
larsif
What did that set you back?
