METHONAL SYSTEM
It's for cooling the intake charge of boosted cars, it cools by using the process of evaporation, by injecting alcohol and meth. into the intake. This process also causes an equivelant to using higher octane fuel.
methanol is mixed with distilled water and injected into the hot boost air. the methanol acts as an octane booster and the water steams and cools the air. good for 40-50hp on a mildly modded boosted motor
THIS INFO IS STRAIGHT FROM SNOW PERFORMANCE
Every Degree of Timing added = 4hp increase
For Every 4pts in Octane increase you can add 2-3 deg of timing or 1-2lb of boost
93 octaneturns into 116 Octane with a 50/50 Water/Methanol Mix
That is a 23 point increase in Octane resulting in 11-17 deg of timing advance or
44 to 68 horsepower increase
This does not act life Nitrous..it does not hit hard...basically it controls detonation and helps a blower car run safer and stronger....
Cant wait until I get mine running again!!!!!!!!!!!!!!!!!!!
bradleyb
Nov 27, 2015 07:50 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
