compression?
Old Jan 25, 2007 | 03:07 AM
greenstreak9205's Avatar
greenstreak9205
Default RE: compression?
actually compression ratio and cylinder compression dont really have anything to do with each other. just like tinman was saying, you can have a really high compression ratio and no cylinder compression. it just shows how well the cylinder can hold the pressure (rings and so on). with a high horsepower engine built to a race type of spec, they use low friction rings. they can get away with using this because they end up tearing down the engines so often anyway. one of my teachers (hot rod teacher actually) is part of the chicago-wise-guys and has lots of toys. he was telling us that one of his cars was lucky to hold about 80 psi in it. not sure what the compression was on it though, but i can tell you that it was a 6 sec car.
Old Jan 25, 2007 | 05:55 AM
94ford5liter's Avatar
94ford5liter
123 and 130 on all the cylinders.
You wouldn't have to rebuild it with that compression. I mean that isnt great but it would still probably last at least a year. Stock compression is supposed to be 8.5:1, and in the cylinders a new 5 liter engine is supposed have around 175. Probably a little lower than that. Although on a 83 i wouldnt be suprised if the ratio is 8:1 and in the cylinder it is 150 new. My numbers are off 87-95. Either way you should be fine.
Old Jan 25, 2007 | 09:26 AM
Eric94GT's Avatar
Eric94GT
I did a compression test on my 82 and it was 130-135.
Old Jan 25, 2007 | 11:44 AM
ahittz24's Avatar
ahittz24
Well we are going to rebuild it anyways, we dont want a motor that will last a year, we want one that will last for years.
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
bconboy
Sep 21, 2015 12:52 PM
uberstang1
Sep 20, 2015 06:42 PM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
