mac underdrive pulleys?
Old Jan 25, 2007 | 06:23 PM
95gtdrop's Avatar
95gtdrop
Default mac underdrive pulleys?
should i buy a set?i can getabrand new setfor 50$ will this be worth the time/effort of puttin em on?
i will not use the alt pulley though.
Old Jan 25, 2007 | 06:31 PM
Js04sILVerBullet's Avatar
Js04sILVerBullet
Default RE: mac underdrive pulleys?
I put the BBK underdrive pulley set on my old weak AOD 87 GT that had 2.73s it couldn't even break the tires loose when hammering it from a stand still. Threw the BBK underdrives on and immeditialy noticed a difference I could actually break the tires loose when I hammered it from a stand still, I was very suprised how well they actually worked. So in my opinion underdrive pulleys r worth the money for how cheap they r.
Old Jan 25, 2007 | 06:36 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
they are a good buy if you dont plan on doing alot of major mods. if all your doing is simple bolt on stuff its worth the money. but the stuff you have to sacrafice for them isnt worth it down the road
Old Jan 25, 2007 | 08:16 PM
PJB's Avatar
PJB
With a '95 there wont be a problem with using the alternator pulley.
Old Jan 25, 2007 | 08:21 PM
Scout2232's Avatar
Scout2232
I have underdrive pulleys(using alt. pulley)on my 88 with an electric fan and its just fine. Drive it every day.
Old Jan 25, 2007 | 08:28 PM
95gtdrop's Avatar
95gtdrop
very good to know.
thanks all
i am gettin em!
ORIGINAL: PJB
Old Jan 25, 2007 | 08:37 PM
2 kwik's Avatar
2 kwik
I ♥ Acer
if they are aluminum.....just using th crank pulley with give you 8 or so hp's with no cooling or charging problems
Old Jan 25, 2007 | 09:00 PM
92hatchLX's Avatar
92hatchLX
I've got a set of black MAC underdrives that I installed as one of my first mods. The UD pullies probably made the biggest SOTP difference. I only installed the crank and water pump pully everything charges fine.
Old Jan 25, 2007 | 10:56 PM
PJB's Avatar
PJB
ORIGINAL: Scout2232
For some reason mine didnt charge very well at idle and the lights dimmed with the underdrive alternator pulley on my 3G alternator. Once I put the stock pulley from the 75 amp alternator back on the charging issues went away.
Old Jan 25, 2007 | 11:00 PM
redmustang83596's Avatar
redmustang83596
Most of the magazines and tech articles say that this is one of the best bang for your buck mods you can do. Definatly worth the price.
