take off the dash bezel and look at the wiring to the switches...i had a prob where my blinkers wouldnt work but my flashers did. i never had a problem with the wipers thought....that might be a differnt problem...but make sure all the wires are together....for both the lights, fog lights, blinkers and defrost switch....they are all linked
yeah its probably the whole switch.. but did you check the actual flasher? (the little metal round piece that plugs into a harness near the fuse box under your dash)?
I had that problem and it wasnt the multifuction switch either it was the ignition switch on the steering column on the other side the the multifuction switch. Its a recall on mustangs for burning out.
