Maf Help!
Old Jan 29, 2007 | 08:46 PM
89stanglx's Avatar
89stanglx
Default Maf Help!
MAF (f3vf-12b579-aa afh80-01) Searching i found this is from a lincoln mark VII 93-95 with #24 injectors 80mm. The plug connectoris the same as mine 89 lx 5.0 and was originally told it was from a cobra, and just needed to adapt the flange to my air inlet hose. I am going to try and make this work. There is really nothing in the ford maf to tell it injector size, it is in my computer right, so im thinking my #19 stock set-up will be just fine, other than overkill on size of the housing.
Old Jan 29, 2007 | 08:50 PM
mattdel's Avatar
mattdel
Default RE: Maf Help!
wrong. the MAF is calibrated for the injectors via the sample tube.
Old Jan 29, 2007 | 09:15 PM
89stanglx's Avatar
89stanglx
Anymore info please, I have read that the computer knows the size of injectors and getting aftermarket mafs and messing with sampling tubes just tries to fool the computer. So i thought getting a cobra maf would work just fine. There is a lot of bad information on maf's and i see it all the time uncorrected, any help is appreciated.
Old Jan 29, 2007 | 09:17 PM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: mattdel
LOL.. you sir, are incorrect
the mark VIII maf will not work properly with the A9* computers in a fox. Look for a 70mm maf from a 94-95 stang... 5.0 and 3.8 will both work
Old Jan 29, 2007 | 09:20 PM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: 89stanglx
this is actually the correct info.
the 93 cobra computer, along with the 94-95 j4j1 computer were tuned to run 24# injectors. The MAF on a 1994-1995 cobra in interchaneable with a MAF from a 1994-1995 GT. the size of the injectors doesnt matter, the stock "calibration" is in the computer
Old Jan 29, 2007 | 09:21 PM
mattdel's Avatar
mattdel
blah
Old Jan 29, 2007 | 09:26 PM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: mattdel
blah
P.S. I get instant updates from the forum when ppl post... "oh wise one"
Old Jan 29, 2007 | 09:28 PM
89stanglx's Avatar
89stanglx
Ok so i bought a cobra #24 maf that should work and got a mark VII maf that wont work with my computer thx.
Old Jan 29, 2007 | 09:29 PM
mattdel's Avatar
mattdel
[sm=icon_blah.gif][sm=imsmilin.gif][sm=shutup.gif]
Old Jan 29, 2007 | 09:32 PM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: 89stanglx
god damn you people are thick
STOCK MAF'S DONT CONTROL INJECTOR SIZE!!!
aftermarket maf's are tuned to "lie" to the computer so that you can run a larger injector without the computer knowing any different
a 1994-1995 maf from a mustang will work with your 19# injectors, because thats what your computer is tuned to use.. even the Cobra maf... will still work with your stock injectors, because the cobra in tuned with a special computer that has different internal values for the 24# injectors
