xe274
Old Jan 30, 2007 | 06:07 PM
zemog's Avatar
zemog
Default xe274
anyone running the xe274 cam in there 302,,if so let me know how you like it.
thanks
z
Old Jan 30, 2007 | 06:15 PM
ruger311's Avatar
ruger311
Default RE: xe274
im running a xe282hr and i love it,, badass if you ask me a bunch of guys run th 274 and they like it
Old Jan 30, 2007 | 06:40 PM
Fosters82GT's Avatar
Fosters82GT
Default RE: xe274
I'm running the XE284 in a 351W and it's a good compromise - not too radical, very easy to drive and sounds nice. I like it.
In my old 302, the cam I had was 224* at .050 on the intake and 500 lift. The XE274 is 230* at .050 and520 lift on the intake. The cam in my 302 was not radical at all and very easy to drive, made pretty good power and had good mid-range torque.
Old Jan 30, 2007 | 06:46 PM
zemog's Avatar
zemog
Default RE: xe274
are you guys having any clearance problems or did you have to do any mods to make it work.
thanks again
z
zemog's Avatar
zemog
Default RE: xe274
guess i should say did you have any problems
Old Jan 30, 2007 | 06:50 PM
ih8chevy's Avatar
ih8chevy
Default RE: xe274
what are the specs on this cam
Old Jan 30, 2007 | 06:55 PM
Fosters82GT
Default RE: xe274
ORIGINAL: ih8chevy
Camshaft Specification Table
Part Number
31-246-3
Engine
1963-1995 Ford
289ci-302ci
8cyl.
Grind Number
FS XE274H-10
Description
[hr]
Intake
Exhaust
Valve Adjustment
Gross Valve Lift
0.52
0.523
Duration At 0.006 Tappet Lift
274
286
[hr]
Valve Timing At 0.006
Open
Close
Intake
31
63
Exhaust
77
29
[hr]
These Specs Are For The Cam Installed At 106 Intake CL
Intake
Exhaust
Duration At 0.05
230
236
Lobe Lift
0.325
0.327
Lobe Separation
110
[hr]
Recommended Valve Springs
986-16
Old Jan 30, 2007 | 06:57 PM
ih8chevy's Avatar
ih8chevy
Default RE: xe274
thanks fosters
Old Jan 30, 2007 | 07:10 PM
Fosters82GT
Default RE: xe274
Here's a link to the Comp Cams catalogue. Scroll down to the Extreme Energy cams (near the top of page 1). You can see the specs of the different cams including the XE274. My old 302 had the XE268 and it was an easy daily driver.
http://www.compcams.com/technical/Ca...85_230-231.pdf
Old Jan 30, 2007 | 07:59 PM
zemog's Avatar
zemog
Default RE: xe274
sorry for the confusion the cam i was referencing was the xe274hr not the h, the specs for the hr are
274/282 duration
555/565 lift
that is why i was concerned if it would work without any modifications and was wanting to know if anyone had it installed.
thanks again
z
