lowered car
if you've got loose steering right now... did you check and make sure your front end components are tight?? i.e. --- wheel bearings, inner tie rods, outer tie rods?? you have to have a tight front end before you get an alignment, otherwise you're pissing money away.
CC kits are like $160....
and just because ur car was inspected dosnt mean the front end is tight. shake it down...
my front end is tight but my steering rack is a leaking bastard and i need to eliminate the rag joint because its lagging the steering response (probably doing the same to yours too)
inyadreems
Aug 21, 2015 09:10 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
